Using the Bilge Pump Switches
You can manually operate connected bilge pumps by using switches 12 and 13 on the Garmin® chartplotter.
  1. From a Garmin chartplotter connected to the same NMEA 2000® network as the Garmin Boat Switch™ device, select Vessel > Switching.
  2. Select an option:
    • Press and hold the bilge pump switch for one second to run the bilge pump for 2 minutes.
    • Press and hold the bilge pump switch for three seconds to run the bilge pump continuously.
      NOTE: Your Garmin chartplotter notifies you every 5 minutes while continuous mode is active.
June 2026
