Transducer Installation Settings
These settings apply to the following types of sonar.
  • Traditional
  • Garmin ClearVü™
  • Garmin SideVü™
From an applicable sonar view, select an option.
  • From a Traditional sonar view, select Options > Sonar Setup > Installation.
  • From a Garmin ClearVü sonar view, select Options > ClearVü Setup > Installation.
  • From a Garmin SideVü sonar view, select Options > SideVü Setup > Installation.
Transmit Rate
Sets the length of time between sonar pings. Increasing the transmit rate increases the scroll speed, but it may also increase self-interference.
Reducing the transmit rate increases the spacing between transmit pulses and can resolve self-interference. This option is available on the Traditional sonar view only.
Transmit Power
Reduces transducer ringing near the surface. A lower transmit power value reduces transducer ringing, but can also reduce the strength of the returns. This option is available on the Traditional sonar view only.
Filter Width
Defines the edges of the target. A shorter filter more clearly defines the edges of the targets but may allow more noise. A longer filter creates softer target edges and may also reduce noise. This option is available on the Traditional sonar view only.
Flip Left/Right
Switches the SideVü view orientation from left to right. This option is available on the SideVü sonar view only.
Restore Sonar Defaults
Restores the sonar settings to the factory default values.
Transducers
View details about installed transducers and save details to a memory card.
Transducers > Change Model
Allows you to change an installed transducer type (Selecting the Transducer Type).
Transducers > Manual Configuration
Allows you to set manual transducer configuration parameters on a compatible sonar module. See the installation instructions for your compatible sonar module for more details on connecting and manually configuring a transducer.
June 2026
