Using Dimmable Lights
You can operate connected dimmable lights by using switches 17 through 21 on the Garmin® chartplotter.
  1. From a Garmin chartplotter connected to the same NMEA 2000® network as the Garmin Boat Switch™ device, select Vessel > Switching.
  2. Select an option:
    • Press a dimmable light switch to turn a light on or off.
      NOTE: The light turns on at the dim level set when the light was last turned off.
    • With a light on, press and hold a dimmable light switch dim the light, and release to stop dimming.
    • With a light off, press and hold a dimmable light switch to turn on the light at 100% brightness.
June 2026
