GPSMAP 9x27 Specifications
Specification
Measurement
Dimensions (W × H × D)
65.5 × 42.3 × 8.5 cm (25.8 × 16.7 × 3.3 in.)
Display size (W × H × diagonal)
59.7 × 33.6 × 68.5 cm (23.5 × 13.2 × 27.0 in.)
Display resolution
4KUHD, 3840 × 2160 pixels
Weight
12.54 kg (27.65 lb.)
Compass-safe distance
81 cm (32 in.)
Temperature range
From -10° to 55°C (from 14° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7
The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
Fuse
15 A
Input voltage
From 10 to 35 Vdc
Max. power usage
97 W
Typical current draw at 12 Vdc
7.2 A
Typical current draw at 24 Vdc
3.3 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 Draw
75 mA max.
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
Memory card
2 microSD® memory card slots, 1 TB max. card size1
Wireless frequency and protocols
Wi‑Fi®, ANT®, and Bluetooth® technologies
2.4 GHz @ 17.21 dBm max.
HTML integration
Compatible with OneHelm™ integration
1 As of software version 34.00, the internal card readers on GPSMAP® 9000 series devices are compatible with up to 1 TB memory cards formatted to exFAT.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v33
September 2025
