Browsing for and Navigating Parallel to a Saved Route
Before you can browse a list of routes and navigate to one of them, you must create and save at least one route (Creating and Saving a Route).
  1. Select Where To > Routes.
    NOTE: Auto Guidance is available with premium charts, in some areas.
  2. Select a route.
  3. Select Navigate To.
  4. Select Offset to navigate parallel to the route.
  5. Select Offset to enter the distance to offset from the route.
  6. Indicate how to navigate the route:
    • To navigate the route from the starting point used when the route was created, to the left of the original route, select Forward - Port.
    • To navigate the route from the starting point used when the route was created, to the right of the original route, select Forward - Starboard.
    • To navigate the route from the destination point used when the route was created, to the left of the original route, select Backward - Port.
    • To navigate the route from the destination point used when the route was created, to the right of the original route, select Backward - Starboard.
  7. If necessary, select Done.
    A magenta line appears. In the center of the magenta line is a thinner purple line that represents the corrected course from your present location to the destination. The corrected course is dynamic, and it moves with your boat when you are off course.
  8. Review the course indicated by the magenta line.
  9. Follow the magenta line along each leg in the route, steering to avoid land, shallow water, and other obstacles.
  10. If you are off course, follow the purple line (corrected course) to go to your destination, or steer back to the magenta line (direct course).
June 2026
