Customizing the Close-Hauled Wind Gauge
You can specify the range of the close-hauled wind gauge for both the upwind scale and the downwind scale.
  1. From the wind gauge, select Options > Edit Gauge Pages.
  2. In the window on the left, select Compass Gauge or Sailing Wind Gauge.
  3. Select Replace Data > Sailing > Close Hauled Gauge.
    The Compass Gauge or Sailing Wind Gauge is replaced by the Close Hauled Gauge.
  4. Select an option:
    • To set the maximum and minimum values that appear when the upwind close-hauled wind gauge appears, select Change Upwind Scale, and set the angles.
    • To set the maximum and minimum values that appear when the downwind close-hauled wind gauge appears, select Change Downwind Scale, and set the angles.
    • To view true or apparent wind, select Wind, and select an option.
June 2026
