DSC List
The DSC list is a log of the most recent DSC calls and other DSC contacts you have entered. The DSC list can contain up to 100 entries. The DSC list shows the most recent call from a boat. If a second call is received from the same boat, it replaces the first call in the call list.
You can view the DSC list from the messages and warnings menu (Messages and Warnings ).
Viewing the DSC List
Before you can view the DSC list, the chartplotter must be connected to a VHF radio that supports DSC.
From a chart or 3D chart view, select Menu button > Layers > Other Vessels > DSC > DSC List.
TIP: You can quickly access the DSC list from the messages and warnings menu (Messages and Warnings ).
Adding a DSC Contact
You can add a vessel to your DSC list. You can make calls to a DSC contact from the chartplotter.
  1. From a chart or 3D chart view, select Menu button > Layers > Other Vessels > DSC > DSC List > Add Contact.
  2. Enter the Maritime Mobile Service Identity (MMSI) of the vessel.
  3. Enter the name of the vessel.
June 2026
