Copying User Data from a Memory Card
You can transfer user data from a memory card to transfer from other devices. User data includes waypoints, routes, Auto Guidance paths, tracks, and boundaries.
NOTE: Only boundary files with an .adm extension are supported.
  1. Insert a memory card into a card slot.
  2. Select Where To.
  3. From the menu bar, select Menu button.
  4. Select Manage User Data > Data Transfer.
  5. If necessary, select the memory card to copy data to.
  6. Select an option:
    • To transfer data from the memory card to the chartplotter and combine it with existing user data, select Merge from Card.
    • To transfer data from the memory card to the chartplotter and overwrite existing user data, select Replace from Card.
  7. Select the file name.
June 2026
