Turning On the Chartplotter Automatically
You can set the chartplotter to turn on automatically when the power is applied. Otherwise, you must turn on the chartplotter by pressing Power button.
Select Settings menu > System > Auto Power Up.
NOTE: When Auto Power Up is On, and the chartplotter is turned off using Power button, and power is removed and reapplied within less than two minutes, you may need to press Power button to restart the chartplotter.
June 2026
