Yamaha Engine Data Settings
NOTICE
Be sure the settings are set correctly. If not, the engine screen will not display the correct information.
From a Yamaha® engine screen, select Options.
Trip
Displays information about the trip, such as distance and hours, and allows you to reset these values.
Maintenance Reminder
Displays maintenance information, enables you to set the maintenance intervals, and allows you to reset the time elapsed since the previous maintenance.
Tank Preset
Sets the tank name, fluid type, sensor style, and tank capacity, and calibrates the sensor.
Trim Assist
Turns the trim assist feature on or off. Available on the Helm Master® system equipped with a digital engine control (DEC) system.
Steer Friction
Sets the friction on the steering wheel. The friction adjusts automatically according to the engine speed. Available on the Helm Master system equipped with a digital engine control (DEC) system.
Lock to Lock
Sets the number of times the steering wheel can be turned between locks, fully to port and fully to starboard.
Speed Control
Sets the speed source to GPS or RPM. Using GPS as the Speed Source is available only with the Helm Master EX system equipped with an autopilot or joystick. GPS is not available on the Helm Master system.
Speed Control > Wave Assist
Turns on the Wave Assist feature for applicable systems.
Speed Control > Wave Assist Level
Sets the sensitivity level for the Wave Assist feature. The higher you set the level, the more the system reacts to wave height and distances when adjusting the speed automatically.
Autopilot Setting
Configures the Yamaha autopilot settings. Available on the Helm Master EX system equipped with an autopilot. For Garmin® autopilot information, see (Autopilot).
Joystick and Set Point
Sets the joystick thrust, trim angle and preset, fine tuning distance, and fish point settings. Available on the Helm Master system and the Helm Master EX system equipped with a joystick.
Trim Assist Preset
Sets up the trim assist presets. Available on the Helm Master system equipped with a digital engine control (DEC) system.
Fuel Flow Offset
Sets the offset for the fuel flow data.
Off Timer
Turns off the system one hour after the engine is turned off.
Battery Management
Configures the battery management system, such as setting the type and capacity of the batteries. Also displays the battery status. Available on Helm Master EX systems equipped with Battery Management System (BMS).
Calibration
Calibrates various features, such as the Trim Zero Set and compass.
Reset
Resets the engine and gateway data.
June 2026
