Mirroring or Rotating the Camera Image
When using a compatible camera, such as a GC™ 245/255, you can change the camera image to better fit the mounting orientation.
  1. From a compatible video screen, select Options.
  2. Select an option:
    • To mirror the image, select Video Setup > Mirror.
    • To rotate the image by 180 degrees, select Installation > Inverted Install.
      NOTE: If your camera was installed by your boat builder, inverted configuration may have already been set and cannot be changed.
June 2026
