Viewing Video
WARNING
Do not view video or photos while operating the vessel. Failure to pay attention to the conditions on the water can result in vessel damage, personal injury, or death.
Before you can view video, you must connect to a compatible source.
Compatible sources include video devices connected to the ports on the chartplotter and supported network (IP-based) video cameras and thermal cameras connected to the Garmin® network.
Protected HDMI® content, HDCP, cannot be shared across the Garmin network to GPSMAP® 8000 series or older charplotters. HDCP content can be shared by a GPSMAP 9000 series chartplotter only to other GPSMAP 9000 series chartplotters connected to the Garmin BlueNet™ network.
  1. From the home screen, select Video.
    All connected video sources are shown.
  2. Select the video source you would like to view.
    NOTE: If you recently connected a video source and the system did not automatically assign a source type, you must first assign it a source type before you can view the video feed (Video Source Types).
June 2026
