Chart Menu
NOTE: Not all settings apply to all charts. Some options require premium maps or connected accessories, such as radar.
NOTE: The menus may contain some settings that are not supported by your installed charts or your present location. If you make changes to those settings, the changes will not impact the chart view.
From a chart, select Options.
Layers
Adjusts the appearance of the different items on the charts (Chart Layers).
Quickdraw Contours
Turns on bottom contour drawing, and allows you to create fishing map labels ( Garmin Quickdraw Contours Mapping).
Settings
Adjusts the chart settings (Chart Settings).
Edit Overlays
Adjusts the data shown on the screen (Customizing the Data Overlays).
June 2026
