Chart Layers
You can turn on and off chart layers and customize features of the charts. Each setting is specific to the chart or chart view being used.
NOTE: Not all settings apply to all charts and chartplotter models. Some options require premium maps or connected accessories.
NOTE: The menus may contain some settings that are not supported by your installed charts or your present location. If you make changes to those settings, the changes will not impact the chart view.
From a chart, select Options > Layers.
Chart
Shows and hides chart-related items (Chart Layer Settings).
My Vessel
Shows and hides items relating to the boat (My Vessel Layer Settings).
Manage User Data
Shows and hides user data, such as waypoints, boundaries, and tracks, and opens user data lists (User Data Layer Settings).
Other Vessels
Adjusts how other vessels are shown (Other Vessels Layer Settings).
Water
Shows and hides depth items (Water Layer Settings).
Quickdraw Contours
Shows and hides Garmin Quickdraw™ Contours data ( Garmin Quickdraw Contours Settings).
Weather
Shows and hides weather-related items (Weather Layer Settings).
June 2026
