USB DRD Settings
The USB-C® dual-role-data (DRD) port on the chartplotter can function as either a USB host or a USB client (device), depending on the needs of the connected device. If your device has this port, it is labeled USB DRD.
Select Settings menu > Communications > USB DRD Setup.
Auto
The USB port automatically changes between host and client (device) mode. This is the default setting and should be appropriate for most connections.
Host
This chartplotter manages a connected client device, such as a card reader or an external touch screen.
Device
This chartplotter is managed by a connected host device. For example, the chartplotter can provide touch output to a host, such as a computer.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v33
September 2025
