GPSMAP 8x17 Specifications
Specification
Measurement
Dimensions (W × H × D)
41.9 × 30.7 × 7.1 cm (16.5 × 12.1 × 2.8 in.)
Display size (W × H)
36.6 × 23.1 cm (14.4 × 9.1 in.)
Display resolution
WUXGA, 1920 × 1200 pixels
Weight
5.2 kg (11.48 lb.)
Compass-safe distance
Device: 53.34 cm (21 in.)
Device and sun cover: 99.06 cm (39 in.)
Sun cover: 48.26 cm (19 in.)
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7 1
Fuse
15 A
Input voltage
From 10 to 35 Vdc
Max. power usage
40 W
Typical current draw at 12 Vdc
2.8 A
Typical current draw at 24 Vdc
1.4 A
Max. current draw
3.5 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 Draw
75 mA max.
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
Wireless frequency and protocols
Wi‑Fi®, ANT®, and Bluetooth® technologies
2.4 GHz @ 17.21 dBm max.
HTML integration
Compatible with OneHelm™ integration
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v35
April 2026
