Viewing Graphs
Before you can view graphs of various environmental changes, such as temperature, depth, and wind, you must have an appropriate transducer or sensor connected to the network.
You can view graphs of sensor data by creating a new Combo page or by adding a graph to an existing Combo page.
  1. Create a new Combo page or open an existing Combo page (Creating a New Combination Page).
  2. Select the window where you want to add a graph, and select Graphs.
  3. Select the graph you want to add.
TIP: You can change the graph in an active combo window by selecting Menu button > Change Graph, and selecting a new graph.
Setting the Graph Range and Time Scales
You can indicate the amount of time and the range of sensor data that appears in the depth, wind, and water temperature graphs.
  1. Select a graph in a Combo page, and select Menu button.
  2. Select an option:
    • To set a time-elapsed scale, select Duration. The default setting is 10 minutes. Increasing the time-elapsed scale allows you to view variations over a longer period of time. Decreasing the time-elapsed scale allows you to view more detail over a shorter period of time.
    • To set the graph scale, select Scale. Increasing the scale allows you to view more variation in readings. Decreasing the scale allows you to view more detail in the variation.
Disabling Graph Filtering
The wind speed and wind angle graph filtering smooths out sensor data before it is displayed on a graph. The default setting is On. You can disable the filtering.
  1. Select a graph in a Combo page, and select Menu button. .
  2. Select Filter > Off.
June 2026
