GPSMAP 8x16 Specifications
Dimensions (W × H × D)
384.7 × 262.6 × 76 mm (151/8 × 105/16 × 3 in.)
Dimensions on bail mount (W × H × D)
405.6 × 279.1 × 103 mm (1515/16 × 11 × 41/16 in.)
Display size (W × H)
345.2 × 194.6 mm (139/16711/16 in.)
15.6 in. diagonal
Display resolution
FHD, 1920 × 1080 pixels
Weight
4.4 kg (9.6 lb.)
Clearance behind flush-mounted device
11.1 cm (43/8  in.)
Compass-safe distance
105 cm (41.3 in.)
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX71
Fuse
10 A, 125 V fast-acting
Input voltage
From 10 to 32 Vdc
Max. power usage at 10 Vdc
52.1 W
Typical current draw at 12 Vdc
1.3 A
Max. current draw at 12 Vdc
6.0 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 draw
75 mA max.
Max. waypoints
5,000
Max. routes
100 (250 waypoints each)
Max. active track points
50,000 points, 50 saved tracks
Memory card
2 microSD® memory card slots, 32 GB max card size.
Wireless frequency and protocols
Wi‑Fi® and ANT® technologies
2.4 GHz @ 12.3 dBm nominal
HTML integration
Compatible with OneHelm™ integration
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
June 2026
