GPSMAP 8700 Specifications
Dimensions (W × H × D)
38.3 × 19.8 × 4.7 cm (151/8× 713/16× 17/8 in.)
Clearance on front of device
8.6 cm (33/8  in.)
Weight
1.39 kg (3.06 lb.)
Compass-safe distance
2.54 cm (1 in.)
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7 1
Fuse
10 A, 42 V fast-acting
Input voltage
From 10 to 32 Vdc
Max. power usage at 10 Vdc
40.1 W
Typical current draw at 12 Vdc
1.5 A
Max. current draw at 12 Vdc
6.0 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 draw
75 mA max.
Max. waypoints
5,000
Max. routes
100 (250 waypoints each)
Max. active track points
50,000 points, 50 saved tracks
HTML integration
Compatible with OneHelm™ integration
Memory card
External card reader required (not included)
Wireless frequency and protocols
Wi‑Fi® and ANT® technologies
2.4 GHz @ 14.15 dBm maximum
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
June 2026
