Sonar Noise Rejection Settings
From a sonar view, select Options > Sonar Setup > Noise Reject.
Interference
Adjusts the sensitivity to reduce the effects of interference from nearby sources of noise.
The lowest interference setting that achieves the desired improvement should be used to remove interference from the screen. Correcting installation issues that cause noise is the best way to eliminate interference.
Color Limit
Hides part of the color palette to help eliminate fields of weak clutter.
By setting the color limit to the color of the undesired returns, you can eliminate the display of undesired returns on the screen.
Smoothing
Removes noise that is not part of a normal sonar return, and adjusts the appearance of returns, such as the bottom.
When smoothing is set to high, more of the low-level noise remains than when using the interference control, but the noise is more subdued because of averaging. Smoothing can remove speckle from the bottom. Smoothing and interference work well together to eliminate low-level noise. You can adjust the interference and smoothing settings incrementally to remove undesirable noise from the display.
Surface Noise
Hides surface noise to help reduce clutter. Wider beam widths (lower frequencies) can show more targets, but can generate more surface noise.
TVG
Adjusts the time varying gain, which can reduce noise.
This control is best used for situations when you want to control and suppress clutter or noise near the water surface. It also allows for the display of targets near the surface that are otherwise hidden or masked by surface noise.
June 2026
