Engaging Wind Hold
Before you can engage wind hold, you must connect a NMEA 2000® wind sensor to the autopilot.
Although a NMEA 2000 wind sensor is preferred, you can connect a NMEA® 0183 wind sensor to the autopilot to use wind hold.
  1. When the autopilot is in standby mode, select Options.
  2. Select an option:
    • To engage an apparent wind hold, select Engage App. Wind Hold.
    • To engage a true wind hold, select Engage True Wind Hold.
    TIP: You can quickly engage the last type of wind hold used by selecting Wind Hold from standby mode.
June 2026
