GPSMAP 9x19 Specifications
Specification |
Measurement |
Dimensions (W × H × D) |
45.7 × 30.5 × 69 cm (18 × 12 × 2.7 in.) |
Display size (W × H × diagonal) |
40.9 × 23 × 46.9 cm (16.1 × 9.1 × 18.5 in.) |
Display resolution |
4KUHD, 3840 × 2160 pixels |
Weight |
6.42 kg (14.16 lb.) |
Compass-safe distance |
46 cm (18 in.) |
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Material |
Polycarbonate plastic and die-cast aluminum |
Water rating |
IEC 60529 IPX7 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating. |
Fuse |
15 A |
Input voltage |
From 10 to 35 Vdc |
Max. power usage |
60 W |
Typical current draw at 12 Vdc |
4.6 A |
Typical current draw at 24 Vdc |
2.3 A |
NMEA 2000® LEN @ 9 Vdc |
2 |
NMEA 2000 Draw |
75 mA max. |
Max. waypoints |
5,000 |
Max. routes |
100 |
Max. active track points |
50,000 points, 50 saved tracks |
Memory card |
2 microSD® memory card slots, 1 TB max. card size1 |
Wireless frequency and protocols |
Wi‑Fi®, ANT®, and Bluetooth® technologies 2.4 GHz @ 17.21 dBm max. |
HTML integration |
Compatible with OneHelm™ integration |
