Configuring the Recording Interval of the Track Log
You can indicate the frequency at which the track plot is recorded. Recording more frequent plots is more accurate but fills the track log faster. The resolution interval is recommended for the most efficient use of memory.
  1. Select Where To > Tracks > Menu button.
  2. Select Interval > Interval
  3. Select an option:
    • To record the track based on a distance between points, select Distance > Change, and enter the distance.
    • To record the track based on a time interval, select Time > Change, and enter the time interval.
    • To record the track plot based on a variance from your course, select Resolution > Change, and enter the maximum error allowed from the true course before recording a track point. This is the recommended recording option.
June 2026
