Tips and Shortcuts (Black Box models)
  • Press Power button to turn on the GPSMAP® 8700 device.
    You can also turn on and off the device using a Garmin® chartplotter on the network or a GRID™ remote control.
    You can put the device to sleep using a GRID 20 remote control, although you cannot use a GRID 20 remote control to turn it on.
  • From any screen, press Power button repeatedly to scroll through the brightness levels when connected to a GRID remote control, or a GRID 20 remote control. This can be helpful when the brightness is so low you cannot see the screen.
  • Select Home button from any screen to open to the home screen.
  • Select Options to open additional settings about that screen.
  • Select Close symbol to close the menu when finished.
  • Press Power button to open additional options, depending on your installation.
  • Depending on the features of your chartplotter, not all feature buttons are visible are on the home screen. Swipe right or left to view the additional feature buttons.
  • On some menu buttons, select the button 1 to enable the option.
    Menu buttons with callouts
    A green light on an option indicates the option is enabled 2.
  • When available, select Menu button 3 to open the menu.
June 2026
