Enabling Power Steering Mode
Before you can select the option to Engage Power Steering on the chartplotter or helm control device, you must first enable power steering mode in the autopilot settings.
NOTE: The option to enable power steering mode is available only when the GNA™ 10 adapter is installed correctly and the vessel type is set to power planing.
From the autopilot page, select Menu button > Autopilot Setup > Power Steering.
The Power Steering setting is enabled, and the option to Engage Power Steering is now available in the autopilot menu.
June 2026
