LED Lighting Control Screen
You can access LED lighting screen by selecting Vessel > Lighting.
LED lighting screen with callouts
Turn off all lights icon
Turns off all connected lights and scenes.
Scenes
Shows all created scenes.
Lights
Shows all connected LED lights and light groups.
Create new scene icon
Creates a new scene.
1
Light, light group, or scene name and information.
Select to turn a light or light group on and off.
Select to start a scene.
2
Shows whether the light or light group on and off.
Adjust brightness icon
Quickly adjust the brightness of the light, light group, or scene.
Edit scene icon
Quickly edit the properties, color, and effects of a light, light group, or scene.
Turning LED Lights On and Off
  1. From the lighting control screen, select Options > Edit Light.
    A list of all available lights and light groups is shown.
  2. Select a light or light group.
  3. Select Turn On or Turn Off.
    TIP: You can select the toggle switch on the light or light group directly from the lighting control screen to quickly turn lights and light groups on and off.
Adjusting LED Light Brightness
  2. Select the light or light group you want to adjust.
  3. Adjust the brightness level on the bottom of the screen for the selected light or light group.
    TIP: You can select Adjust brightness icon on the light or light group directly from the lighting control screen to quickly adjust the brightness for a light or group of lights.
Changing LED Light Color
  3. Select Color Pick > Color.
  4. Depending on the type of light connected, select an option:
    • To change the RGB color of a connected light, select Color.
    • To change the tone of a white light, select White.
    A color or white light gradient window is shown, along with a set of predefined colors or white light selections.
  5. Select a color or white tone.
    TIP: You can select Edit scene icon on the light or light group directly from the lighting control screen to quickly adjust the color or effect for a light or group of lights.
Changing LED Light Effects
WARNING
Selecting some LED light effects may result in lights flashing at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
  3. Select Effects > Effect.
    A list of predefined lighting effects is shown
  4. Select an effect from the list.
    The screen shows the colors and pattern included in the effect, and the affected light or light group starts using the selected effect.
  5. If necessary, select Effect, and choose a different effect until the light or group of lights uses the preferred effect.
    TIP: You can select Edit scene icon on the light or light group directly from the lighting control screen to quickly adjust the effect or color for a light or group of lights.
Setting LED Lights to React to Music
You must associate a light or light group with an audio zone on a connected compatible stereo before you can use the Audio Sync feature and have the lights react to music playing on the stereo (Associating LED Lights with an Audio Zone).
WARNING
Setting LED lights to react to music may result in lights flashing at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
  3. Select Audio Sync.
    • If you want the lights to react to quieter and louder elements of the music playing, select Mode > Color Blend.
    • If you want the lights to react to the bass and treble frequencies of the music playing, Mode > Audio Spectrum.
  5. If necessary, select the colors associated with the quieter, louder, bass, and treble elements depending on the selected mode.
June 2026
