Adding and Editing a Digital Switching Page
You can add and customize digital switching pages on the chartplotter.
  1. Select Vessel > Switching > Options > Setup.
  2. Select Add Page or Edit Page.
  3. Set up the page as needed:
    • To enter a name for the page, select Name.
    • To set up the switches, select Edit Switches.
    • To add an image of the boat, select Add BoatView Image.
      NOTE: You can use the default vessel image or use a custom image of your vessel. You should save the custom image to the /Garmin folder on the memory card. You can also adjust the view and placement of the image.
June 2026
