Changing the Wi‑Fi Host
If there are multiple chartplotters with Wi‑Fi® technology on the Garmin® marine network, you can change which chartplotter is the Wi‑Fi host. This can be helpful if you are having trouble with Wi‑Fi communications. Changing the Wi‑Fi host allows you to select a chartplotter that is physically closer to your mobile device.
  1. Select Settings menu > Communications > Wi-Fi Network > Advanced > Wi-Fi Host.
  2. Follow the on-screen instructions.
June 2026
