Configuring the Function Keys
The two keys labeled 1 and 2 on the keypad can be configured using a compatible chartplotter or a GHC™ 50 helm control connected to the autopilot system.
  1. From the autopilot screen, select Options > Autopilot Setup > Autopilot Keypad > Autopilot Keypad Configuration
  2. Select an option:
    • To configure the key labeled 1, select Key 1.
    • To configure the key labeled 2, select Key 2.
  3. Select the function you want to assign to the key.
  4. Repeat this procedure for the other key, if needed.
June 2026
