Recording an Indoor Climbing Activity
You can record routes during an indoor climbing activity. A route is a climbing path along an indoor rock wall.
  1. From the watch face, press START.
  2. Select Climb Indoor.
    The first time you start an activity, you can enable route statistics.
  3. Select a grading system.
    NOTE: The next time you start an indoor climbing activity, the watch uses these activity settings.
  4. Select the difficulty level for the route.
  5. Press START.
  6. Start your first route.
  7. When you finish the route, descend to the ground.
    The rest timer starts automatically when you are on the ground.
    NOTE: If necessary, you can press Lap symbol to finish the route.
  8. Select an option:
    • To save a successful route, select Completed.
    • To save an unsuccessful route, select Attempted.
    • To delete the route, select Discard.
  9. Enter the number of falls for the route.
  10. When you are done resting, press Lap symbol , and begin your next route.
  11. Repeat this process for each route until your activity is complete.
  12. After you complete your activity, press STOP, and select Save.
June 2025
