Using the inReach Remote
Before you can use the inReach® remote function, you must add the inReach glance to the glance loop (Customizing the Glance Loop).
  1. Turn on the inReach device.
  2. On your Forerunner® watch, press UP or DOWN from the watch face to view the inReach glance.
  3. Press START to search for your inReach device.
  4. Press START to pair your inReach device.
  5. Press START, and select an option:
    • To send an SOS message, select Initiate SOS.
      NOTE: You should only use the SOS function in a real emergency situation.
    • To send a text message, select Messages > New Message, select the message contacts, and enter the message text or select a quick text option.
    • To send a preset message, select Send Preset, and select a message from the list.
    • To view the timer and distance traveled during an activity, select Tracking.
June 2025
