Navigation Settings
You can customize the map features and appearance when navigating to a destination.
Customizing Navigation Data Screens
  1. Hold Menu symbol.
  2. Select Navigation > Data Screens.
  3. Select an option:
    • Select Map > Status to turn on or off the map.
    • Select Map > Data Field to turn on or off a data field that shows routing information on the map.
    • Select Up Ahead to turn on or off information about upcoming course points.
    • Select Compass to turn on or off the compass.
    • Select Elevation Plot to turn on or off the elevation plot.
    • Select a screen to add, remove, or customize.
Setting Up a Heading Bug
You can set up a heading indicator to display on your data pages while navigating. The indicator points to your target heading.
  2. Select Navigation > Heading Bug.
Setting Navigation Alerts
You can set alerts to help you navigate to your destination.
  2. Select Navigation > Alerts.
    • To set an alert for a specified distance from your final destination, select Final Distance.
    • To set an alert for the estimated time remaining until you reach your final destination, select Final ETE.
    • To set an alert when you stray from the course, select Off Course.
    • To enable turn-by-turn navigation prompts, select Turn Prompts.
  4. If necessary, select Status to turn on the alert.
  5. If necessary, enter a distance or time value, and select Checkmark symbol.
June 2025
