Customizing the Controls Menu
You can add, remove, and change the order of the shortcut menu options in the controls menu (Controls).
  1. Hold Menu symbol.
  2. Select Appearance > Controls.
  3. Select a shortcut to customize.
  4. Select an option:
    • Select Reorder to change the location of the shortcut in the controls menu.
    • Select Remove to remove the shortcut from the controls menu.
  5. If necessary, select Add New to add an additional shortcut to the controls menu.
June 2025
