Viewing the Map
You can add the map as a data screen to any GPS activity (Customizing the Data Screens).
  1. Select an option to open the map:
    • Press START, and select Map to view the map without starting an activity.
    • Go outside, start a GPS activity (Starting an Activity), and press UP or DOWN to scroll to the map screen.
  2. If necessary, wait while the watch locates satellites.
  3. Select an option to pan and zoom the map:
    • To use the touchscreen, tap the map, tap and drag to position the crosshairs, and press UP or DOWN to zoom in or out.
      NOTE: The touchscreen is not enabled for all activities (Activities and App Settings).
    • To use the buttons, hold Menu symbol, select Pan/Zoom, and press UP or DOWN to zoom in or out.
      NOTE: You can press START to toggle between panning up and down, panning left and right, or zooming.
June 2025
