Managing Maps
When you connect your watch to a Wi‑Fi® network, you can download maps for additional regions. You can also remove maps to increase the available device storage.
  1. Hold Menu symbol.
  2. Select Map > Map Manager.
  3. Select a map category.
  4. Select an option:
    • To download a map, select Add Map, select a map, press START, and select Download.
      NOTE: To prevent battery drain, the watch queues the map download for later, and the download starts when you connect the watch to an external power source.
    • To remove a map, select a map, press START, and select Remove.
June 2025
