Showing and Hiding Map Data
You can choose the map data to show on the map and save map data themes for multiple activities.
  1. From the watch face, press START.
  2. Select Map.
  3. Press START.
  4. Select Map Layers.
  5. Select an option:
    • To customize the map data for an activity type, select Activity Theme, and select an activity.
      Changes you make to the map data settings are saved to the selected activity theme.
    • To select the installed map product to display, select Map Type, and select a map product.
    • To turn on specific map features, such as activity lines or saved locations, select the map feature, and select Status > On.
      TIP: You can select Apply to all Activities to apply the setting to all activity themes.
    • To view your downloaded map versions or download additional maps, select Get More Maps (Managing Maps).
June 2025
