Customizing Activities and Apps
You can customize the activities and apps list, data screens, data fields, and other settings.
Adding or Removing a Favorite Activity
The list of your favorite activities appears when you press START from the watch face, and it provides quick access to the activities you use most frequently. The first time you press START to start an activity, the watch prompts you to select your favorite activities. You can add or remove favorite activities at any time.
  1. Hold Menu symbol.
  2. Select Activities & Apps.
    Your favorite activities appear at the top of the list.
  3. Select an option:
    • To add a favorite activity, select the activity, and select Set as Favorite.
    • To remove a favorite activity, select the activity, and select Remove from Favorites.
Changing the Order of an Activity in the Apps List
  3. Select an activity.
  4. Select Reorder.
  5. Press UP or DOWN to adjust the position of the activity in the apps list.
Creating a Custom Activity
  1. From the watch face, press START.
  2. Select Add.
    • Select Copy Activity to create your custom activity starting from one of your saved activities.
    • Select Other to create a new custom activity.
  4. If necessary, select an activity type.
  5. Select a name or enter a custom name.
    Duplicate activity names include a number, for example: Bike(2).
  6. Select an option:
    • Select an option to customize specific activity settings. For example, you can customize the data screens or auto features.
    • Select Done to save and use the custom activity.
  7. Select Yes to add the activity to your list of favorites.
June 2025
