Changing the Bands
You can replace the bands with new Forerunner® bands or compatible QuickFit® 22 bands.
  1. Use the pin tool to push in the watch pin.
    Watch with the pin tool
  2. Remove the band from the watch.
  3. Select an option:
    • To install Forerunner bands, align one side of the new band with the holes on the device, push in the exposed watch pin, and press the band into place.
      NOTE: Make sure the band is secure. The watch pin should align with the holes on the device.
    • To install QuickFit 22 bands, remove the watch pin from the Forerunner band, replace the watch pin on the device, and press the new band into place.
      Watch with the QuickFit band
      NOTE: Make sure the band is secure. The latch should close over the watch pin.
  4. Repeat the steps to change the other band.
June 2025
