System Settings
Hold , and select
- Language
Sets the language displayed on the watch.
- Passcode
Sets a four-digit passcode to secure your personal information when the watch is not on your wrist (Setting Your Watch Passcode).
- Time
Adjusts the time settings (Time Settings).
- Display
Adjusts the screen settings (Changing the Screen Settings).
- Touch
Allows you to enable or disable the touchscreen during general use, activities, or sleep.
- Satellites
Sets the default satellite system to use for activities. If necessary, you can customize the satellite setting for each activity (Satellite Settings).
- Sound and Vibe
Sets the watch sounds, such as button tones, alerts, and vibrations.
- Sleep Mode
Allows you to set your sleep hours and sleep mode preferences (Customizing Sleep Mode).
- Do Not Disturb
Allows you to enable the Do Not Disturb mode. You can edit your preferences for the screen, notifications, alerts, and wrist gestures.
- Hot Keys
Allows you to assign shortcuts to buttons (Customizing the Hot Keys).
- Auto Lock
Allows you to lock the buttons and touchscreen automatically to prevent accidental button presses and touchscreen swipes. Use the During Activity option to lock the buttons and touchscreen during a timed activity. Use the Not During Activity option to lock the buttons and touchscreen when you are not recording a timed activity.
- Format
Sets general format preferences, such as the units of measure, pace and speed shown during activities, the start of the week, and geographical position format and datum options (Changing the Units of Measure).
- Performance Condition
Enables the performance condition feature during an activity (Performance Condition).
- Data Recording
Sets how the watch records activity data. The Smart recording option (default) allows for longer activity recordings. The Every Second recording option provides more detailed activity recordings, but may not record entire activities that last for longer periods of time.
- USB Mode
Sets the watch to use MTP (media transfer protocol) or Garmin® mode when connected to a computer.
- Reset
Allows you to reset user data and settings (Resetting All Default Settings).
- Back Up & Restore
Allows you to enable automatic backups of watch data and settings and back up your data now. You can restore data from a previous backup using the Garmin Connect™ app (Back Up and Restore Settings).
- Software Update
Allows you to install downloaded software updates, enable automatic updates, or manually check for updates (Product Updates).
- About
Displays device, software, license, and regulatory information.
- Time Settings
- Changing the Screen Settings
- Customizing the Hot Keys
- Changing the Units of Measure
- Setting Your Watch Passcode
- Back Up and Restore Settings
