Setting Up the Timed Transmit Mode
To help conserve power, you can set up time intervals in which the radar will transmit and not transmit (standby) signal transmissions.
NOTE: This feature is not available in dual radar modes.
  1. From a radar screen, select Options > Radar Options > Timed Transmit.
  2. Select Timed Transmit to enable the option.
  3. Select Stdby Time, enter the time interval between radar signal transmissions, and select Done.
  4. Select Transmit Time, enter the duration of each radar signal transmission, and select Done.
September 2026
