Mercury Engine Gauges
NOTE: This feature is available only when connected to the Mercury® SmartCraft Connect gateway. The available data varies based on the engine network and may include RPM, engine hours, coolant pressure, oil pressure, and other data.
Select Gauges > Mercury to view the Mercury engine gauges.
Mercury gauges screen with callouts
1
Engine voltage or Mercury Steering Angle1
2
Boat status
3
Boat speed
4
Fuel
5
Transmission gear
6
Engine speed
7
Trim tabs
8
Engine trim
TIP: To view additional engine details, select Options > Engine Data.
1 The Mercury Steering Angle may appear on the display, depending on the engine model and configuration, and its location on the display may vary.
September 2026
