Calibrating the Steering Alignment
The Garmin® trolling motor shaft is aligned at the factory by Garmin, and should not need regular alignment. Occasionally, due to an impact or an unexpected manual shaft rotation, the trolling motor steering may appear off, or you may receive an error message regarding the steering alignment. You can perform this alignment procedure to correct this type of error.
  1. Deploy the trolling motor.
  2. From the trolling motor bar, select Menu symbol > Calibrate > Steering Alignment.
  3. Follow the on-screen instructions and select Begin.
    NOTICE
    The trolling motor will perform a number of steering motions during the calibration process.
  4. Wait until the calibration process is complete.
September 2026
