Renaming a Sonar Source
You can rename a sonar source to easily identify that source. A sonar source is associated with the chartplotter or sounder module with a connected transducer. For example, you can use "Bow" as the name of the chartplotter installed on the bow of your boat with a connected transducer.
  1. Select Settings menu > Communications > BlueNet™ Network.
  2. Select the chartplotter or sounder module you want to rename.
  3. Select Change Name.
  4. Enter the name.
September 2026
