Sharing and Managing User Data
WARNING
This feature allows you to import data from other devices that may have been generated by third parties. Garmin® makes no representations about the accuracy, completeness, or timeliness of data that is generated by third parties. Any reliance on or use of such data is at your own risk.
You can share user data between compatible devices. User data includes waypoints, saved tracks, routes, and boundaries.
  • User data is shared with other devices connected to the Garmin BlueNet™ network or Garmin Marine Network.
  • You can share and manage user data between different devices using a memory card. The memory card you use must be formatted to a file type supported by all devices that you want to share user data. For example, if you have one device that supports only FAT32 format cards and another device that supports exFat format cards, you should use a card formatted to FAT32 so that it can be read by both devices (Memory Cards).
GUID-3E67C80C-0812-4EEC-BC60-699751B9CF6F v15
June 2026
