Mercury Cruise Control
WARNING
You are responsible for the safe and prudent operation of your vessel. Mercury® Cruise Control does not steer the boat for you and does not avoid navigational hazards. Failure to safely operate your boat could result in an accident causing property damage, serious personal injury, or death.
When connected to a compatible Mercury engine, you can set and adjust the cruise-control function using the chartplotter.
Enabling the Mercury Cruise Control Overlay
  1. From the page where you want to add the overlay, select Options > Edit Overlays.
    TIP: You can also select Toolbars from the menu bar to quickly change the overlays.
  2. Select Top Bar, Bottom Bar, Left Bar, or Right Bar.
  3. Select Mercury Cruise.
  4. Select Back.
Mercury control bar with callouts
Minus symbol
Select to decrease the target speed
1
Target speed
Plus symbol
Select to increase the target speed
2
Actual speed
Enable
Select to engage the cruise control
Disable
Select to disengage the cruise control
September 2026
