GPSMAP 16x3 Specifications
Dimensions (W × H × D)
384.7 × 266.4 × 78 mm (15 1/8 × 10 1/2 × 3 1/16 in.)
Dimensions with cover on bail mount (W × H × D)
405.9 × 277.3 × 110 mm (16 × 10 15/16 × 4 3/8 in.)
Clearance to next obstruction behind chartplotter
94 mm (3 3/4 in.)
Display size (W × H)
345.2 × 194.6 mm (13 9/16 × 7 11/16 in.)
396.3 mm (15 5/8 in.) diagonal
Display resolution
FHD, 1920 × 1080 pixels (IPS)
Weight
4.45 kg (9.8 lb.)
Compass-safe distance
85 cm (33.5 in.)
Max. power usage at 10 Vdc
Non-sonar models: 46.0 W
Sonar models: 74.75 W
Typical current draw at 12 Vdc
Non-sonar models: 2.90 A
Sonar models: 3.61 A
Max. current draw at 12 Vdc
Non-sonar models: 3.73 A
Sonar models: 6.07 A
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7 1
Input voltage
From 10 to 32 Vdc
Fuse
8 A, 125 V fast-acting
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 draw
75 mA max.
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
Wireless frequency
2.4 GHz @ 19.7 dBm max.
Memory card
2 microSD® memory card slots, 1 TB max. card size2
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
2 As of software version 34.00, GPSMAP® 16x3 series devices are compatible with up to 1 TB memory cards formatted to exFAT.
GUID-3E67C80C-0812-4EEC-BC60-699751B9CF6F v15
June 2026
