Measuring Distance on the Sonar Screen
You can measure the distance between two points on the SideVü sonar view.
  1. From the SideVü sonar view, select Pause symbol.
  2. Select a location on the screen.
  3. Select Measure.
    A push pin appears on the screen at the selected location.
  4. Select another location.
    The distance and angle from the pin is listed in the upper-left corner.
TIP: To reset the pin and measure from the current location of the pin, select Set Reference.
September 2026
