Setting and Following an Auto Guidance Path
  1. Select a destination (Destinations).
  2. Select Navigate To > Auto Guidance.
  3. Review the path, indicated by the magenta line.
  4. Select Start Navigation.
  5. Follow the magenta line, steering to avoid land, shallow water, and other obstacles (Route Color Coding).
    NOTE: When using Auto Guidance, a gray segment within any part of the magenta line indicates that Auto Guidance cannot calculate part of the Auto Guidance line. This is due to the settings for minimum safe water depth and minimum safe obstacle height.
September 2026
