LiveVü and Garmin FrontVü Appearance Settings
From a LiveVü or Garmin FrontVü™ Panoptix™ sonar view, select Options > Sonar Setup > Appearance.
Color Scheme
Sets the color palette.
Color Gain
Adjusts the intensity of colors shown on the screen.
You can select a higher color gain value to see targets higher in the water column. A higher color gain value also allow you to differentiate low intensity returns higher in the water column, but this causes a loss in the differentiation of the returns at the bottom. You can select a lower color gain value when targets are near the bottom, to help you distinguish between targets and high intensity returns such as sand, rock, and mud.
Trails
Sets the how long the trails appear on the screen. The trails show the movement of the target.
Bottom Fill
Colors the bottom brown to distinguish it from the water returns.
September 2026
