Radar Installation Settings
Front of Boat
Compensates for the physical location of the radar when it is not on the boat axis (Measuring and Setting the Front-of-Boat Offset).
Antenna Configuration
Sets the radar antenna size and sets the position in which the radar stops (Setting a Custom Park Position).
No Transmit Zone
Sets the area in which the radar does not transmit signals (Enabling and Adjusting a Radar No Transmit Zone).
The front-of-boat offset compensates for the physical orientation of the radar scanner on a boat, if the radar scanner does not align with the bow-stern axis. The front-of-boat offset setting configured for use in one radar mode is applied to every other radar mode and to the radar overlay.
  1. Using a magnetic compass, take an optical bearing of a stationary target located within viewable range.
  2. Measure the target bearing on the radar.
  3. If the bearing deviation is more than +/- 1 degree, set the front-of-boat offset.
  4. From a radar screen, select Options > Radar Setup > Installation > Front of Boat.
  5. Select Up or Down to adjust the offset.
By default, the antenna is stopped perpendicular to the pedestal when it is not spinning. You can adjust this position.
  1. From the radar screen, select Options > Radar Setup > Installation > Antenna Configuration > Park Position.
  2. Use the slider bar to adjust the position of the antenna when stopped, and select Back.
September 2026
